Einleitung
Replacing the battery of an Acer Aspire One Cloudbook AO1-132-C3T3 is a straightforward, yet a crucial task to ensure the continued performance of the laptop. Overtime, the batteries tend to wear down and become less efficient. Replacing an old battery with a new battery will improve the efficiency and the durability of the laptop. In this guide we will walk through on how to disconnect the battery and replace a battery without rupturing any other components of the laptop.
Was du brauchst
Remove eleven 4 mm Phillips #1 screws.
Pull the backplate off using your fingers.
Remove three 3 mm Phillips #1 screws holding down the battery.
Lift the top edge of the battery and pull back towards the hinges to remove the battery.
Eine weitere Person hat diese Anleitung absolviert.
