Zum Hauptinhalt wechseln
Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement
Was du brauchst
  1. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove eleven 4 mm Phillips #1 screws.
    • Pull the backplate off using your fingers.
  2. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: Schritt 2, Bild 1 von 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Pull the rainbow cord out of the motherboard using the tabs on the sides.
  3. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: Schritt 3, Bild 1 von 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove three 3 mm Phillips #1 screws holding down the battery.
    • Lift the top edge of the battery and pull back towards the hinges to remove the battery.
  4. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Remove two 4 mm screws holding down the metal plate using a Phillips #1 screwdriver.
    • Remove the plate using your fingers.
    • Remove four 5 mm screws holding the motherboard in place using a Phillips #1 screwdriver.
  5. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Pull the yellow cord out from the motherboard using the sticker.
  6. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: Schritt 6, Bild 1 von 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Pull both small blue ribbon cords out of the motherboard using the stickers.
  7. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Gently pull the black cord out from the motherboard.
  8. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Pull the top cord out of the motherboard using the sticker.
  9. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Gently pull the motherboard away from the small square chip to its left.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Hello, can you please advise on how to replace the ram on this laptop
BenfromEssex - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 1,080
