Einleitung
In this guide, you will remove the USB Port from the device by removing two screws and disconnecting the ribbon cable connecting it to the motherboard.
Was du brauchst
Remove eleven 4 mm Phillips #1 screws
Pull the backplate off using your fingers.
Now that the port can be lifted up, remove the ribbon cable by using the sticker attached to it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
