Einleitung
If the Acer Aspire One D255-1625 will not connect to the internet, use this guide to replace your wireless card.
The wireless card allows a computer to connect to the internet by using frequencies transmitted by a router or a cellular tower. A damaged or defective wireless card will not allow your device to connect to the internet.
Before replacing the wireless card make sure to see our guide “Acer Aspire One D255-1625 Wireless Card Troubleshooting”.
Was du brauchst
Pull the upper left switch on the back of the laptop to the left into the unlock position.
Pull the upper right switch to the left and hold it in place.
Use iFixit’s Jimmy tool to remove the bottom panel of the device.
Wedge the tool into the top middle of the panel and slide back and forth across the edge until the back gently pops off.
Use tweezers to disconnect the black and white wires from the wireless card by pulling them up off the card.
Use a Phillips #1 screwdriver to unscrew the top right screw on the wireless card.
Pull out wireless card by sliding it out to your right.
Ein Kommentar
Awesome I changed wireless card with your instruction this is a helpful 👍👍
