Zum Hauptinhalt wechseln
Acer Aspire One D225-1625 Wireless Card Replacement
Was du brauchst
  1. Acer Aspire One D225-1625 Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Aspire One D225-1625 Wireless Card Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Aspire One D225-1625 Wireless Card Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D225-1625 Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: Schritt 3, Bild 1 von 2 Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: Schritt 3, Bild 2 von 2
    • Use iFixit’s Jimmy tool to remove the bottom panel of the device.
    • Wedge the tool into the top middle of the panel and slide back and forth across the edge until the back gently pops off.
  4. Acer Aspire One D225-1625 Wireless Card Replacement: Schritt 4, Bild 1 von 2 Acer Aspire One D225-1625 Wireless Card Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to disconnect the black and white wires from the wireless card by pulling them up off the card.
  5. Acer Aspire One D225-1625 Wireless Card Replacement: Schritt 5, Bild 1 von 2 Acer Aspire One D225-1625 Wireless Card Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #1 screwdriver to unscrew the top right screw on the wireless card.
    • Pull out wireless card by sliding it out to your right.
Abschluss
Ein Kommentar
Awesome I changed wireless card with your instruction this is a helpful 👍👍
sohil shekh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 543
