Zum Hauptinhalt wechseln
Acer Aspire One D255-1625 Battery Replacement
Was du brauchst
  1. Acer Aspire One D255-1625 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Aspire One D255-1625 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Aspire One D255-1625 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 Battery Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 584
