Zum Hauptinhalt wechseln
Acer Aspire One D255-1625 Fan Replacement
Was du brauchst
  1. Acer Aspire One D255-1625 Fan Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Aspire One D255-1625 Fan Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Aspire One D255-1625 Fan Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 Fan Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 Fan Replacement, Fan: Schritt 3, Bild 1 von 2 Acer Aspire One D255-1625 Fan Replacement, Fan: Schritt 3, Bild 2 von 2
    • Use iFixit’s Jimmy tool to remove bottom panel of device.
    • Wedge the tool into the top middle of the panel until the back gently pops off.
  4. Acer Aspire One D255-1625 Fan Replacement: Schritt 4, Bild 1 von 3 Acer Aspire One D255-1625 Fan Replacement: Schritt 4, Bild 2 von 3 Acer Aspire One D255-1625 Fan Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use the tweezers to disconnect the fan's wires from laptop.
    • Use the Phillips #1 screwdriver to remove the three 4mm screws that hold the fan in place.
    • The 3rd screw on the bottom right is extremely difficult to remove as it requires you to bend the motherboard slightly in order to reach it.
  5. Acer Aspire One D255-1625 Fan Replacement: Schritt 5, Bild 1 von 1
    • Pull the fan out of the housing unit.
    • You may need to use the iFixit Jimmy tool to help pull the fan out.
Abschluss
Zahria Martin
196 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 416
