Zum Hauptinhalt wechseln
Acer Aspire One D255-1625 Keyboard Replacement
Was du brauchst
  1. Acer Aspire One D255-1625 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Aspire One D255-1625 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Aspire One D255-1625 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 2 Acer Aspire One D255-1625 Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Use iFixit's Jimmy tool and press it into the small tabs at the top of the keyboard and lift up.
    • Do this for all five tabs at the top of the keyboard.
  4. Acer Aspire One D255-1625 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Slide the Jimmy tool along the top of the keyboard once all tabs have been pressed in.
  5. Acer Aspire One D255-1625 Keyboard Replacement: Schritt 5, Bild 1 von 3 Acer Aspire One D255-1625 Keyboard Replacement: Schritt 5, Bild 2 von 3 Acer Aspire One D255-1625 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Flip the keyboard forward to expose its connection.
    • Slide the small brown tab out to disconnect the keyboard.
    • Lift the keyboard away from the laptop.
    • If you see that the keyboard is not connected upon flipping, reconnect it and see if it works. If not, continue to replace the keyboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Zahria Martin
196 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 343
