Zum Hauptinhalt wechseln
Acer Aspire One D255-1625 RAM Replacement
Was du brauchst
  1. Acer Aspire One D255-1625 RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Aspire One D255-1625 RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Aspire One D255-1625 RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 RAM Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • Use iFixit’s Jimmy tool to remove the bottom panel of the device.
    • Wedge the tool into the top middle of the panel until the back gently pops off.
  4. Acer Aspire One D255-1625 RAM Replacement: Schritt 4, Bild 1 von 3 Acer Aspire One D255-1625 RAM Replacement: Schritt 4, Bild 2 von 3 Acer Aspire One D255-1625 RAM Replacement: Schritt 4, Bild 3 von 3
    • Push the silver locking tabs on either side of the RAM card outward and the card will pop up to rest at an angle.
    • Slide the card straight out of its housing.
Abschluss
2 Kommentare
I was lazy to do it the proper way and thought this was a short cut... Sadly the author is an a*** and doesn't show that there are two screws connected to the bottom plastic base. Well I ripped them right off. The right way is to remove the key board and then unscrew the two screws after that you can pop the bottom panel.
YuraD95 - Antwort
Sorry I was wrong it's not 2 screws it was 5 screws that I ripped off.
YuraD95 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 376
