Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Though the back panel is not itself a component that is often replaced you will need to remove it in order to get to various components inside the computer. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew seven 1.2 mm Phillips #1 screws from the back of the device Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
    • Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
  2. Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer. Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
    • Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
  3. Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand. It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts. It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
    • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
Abschluss
Brian
1.134 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 16-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S16G8
2 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 39
