Einleitung
The hard drive is one of the more crucial components on a computer. There are a variety of different reasons one would want to replace a hard drive including upgrading the size and replacing a malfunctioning component. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
Was du brauchst
Using plastic opening tools press down the 6 clips located around the keyboard.
Using a spudger gently push the tab on the port forward then pull out the cable.
Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
13 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
It is not at all necessary to remove all those screws! Only the 4 marked DOOR under the keyboard are required to pop off the back cover and access the HDD.
Thank you very much, i thought, must to unscrew all the screws like to disassembly all the mini. I THINK is not nessesary neither, the keyboard
Gabo -
Bonjour il n est pas nécessaire d ôter le clavier pour atteindre le disque dur et la carte mémoire par contre il y a un tout petit boulon à ôter en plus de la vis pour enlever le disque dur
