Einleitung
The keyboard is the most essential input component on a laptop. Though this component is designed to have frequent usage either with old age or bad treatment this component may have to be replaced. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
Was du brauchst
Using plastic opening tools press down the 6 clips located around the keyboard.
Using a spudger gently push the tab on the port forward then pull out the cable.
3 weitere Personen haben diese Anleitung absolviert.
