Zum Hauptinhalt wechseln
Acer Aspire One Happy Display Replacement
  1. Acer Aspire One Happy Display Replacement, Display: Schritt 1, Bild 1 von 2 Acer Aspire One Happy Display Replacement, Display: Schritt 1, Bild 2 von 2
    • Remove the adhesive pads that covers 2 screws
    • Remove the screws that hold the front bezel to the back shell
  2. Acer Aspire One Happy Display Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by pulling it out.
  3. Acer Aspire One Happy Display Replacement: Schritt 3, Bild 1 von 3 Acer Aspire One Happy Display Replacement: Schritt 3, Bild 2 von 3 Acer Aspire One Happy Display Replacement: Schritt 3, Bild 3 von 3
    • Using a thin tool , unclip the front bezel from the back shell, along side the perimeter. It holds by pressure clips that release upon touch.
    • Remove the bezel
  4. Acer Aspire One Happy Display Replacement: Schritt 4, Bild 1 von 3 Acer Aspire One Happy Display Replacement: Schritt 4, Bild 2 von 3 Acer Aspire One Happy Display Replacement: Schritt 4, Bild 3 von 3
    • Remove the 4 screws that secure the LCD panel from the back shell
    • Place gently the display on the keyboard, minding any of the cables that may still be connected and the adhesive tape
    • Disconnect all of the cables and remove the Display
Abschluss
To re-assemble your device, follow these steps in reverse order.
it en
100%
Hier starten ›
Smilzo
11.783 Reputation
39 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 434
