Einleitung
Use this disassembly guide to learn how to disassemble certain parts of your Acer laptop.
Remove the keyboard by using a lever-like motion with thin tools on the joints along the keyboard.
Carefully lift and disconnect the flat cable from the motherboard
Remove hard disk screw
Disconnect the cable shown on image 2.
With a thin tool, unhook the hooks that hold the upper shell together from the central shell. Separate them.
Unclip the connectors
Remove the 3 screws securing the card in place. Remove the card after it is free
Remove the speaker
Release the connectors
Remove the 2 screws that secure the motherboard to the laptop
Remove both of the left and right screws holding the display assembly to the laptop
Remove the adhesive that covers the 2 screws.
With an opening pick or Jimmy, seperate the bezel from the LCD assembly.
Remove the bezel
Remove the 4 screws on the display
Disconnect the display cable
Remove the LCD
To reassemble your device, follow these steps in reverse order.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Besonderer Dank geht an diese Übersetzer*innen:
100%
Diese Übersetzer*innen helfen uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
