Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This will show you how to take off the back panel to get into the interior of the netbook.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Close the netbook and turn it over so the back panel faces you.
    • Close the netbook and turn it over so the back panel faces you.
  2. Locate the 4 mm Phillips #1 screw at the bottom of the back panel. Using the Phillips head screwdriver, remove the screw. Place the screw somewhere it will not be lost. Then remove the back panel by gently sliding it towards the front.
    • Locate the 4 mm Phillips #1 screw at the bottom of the back panel. Using the Phillips head screwdriver, remove the screw. Place the screw somewhere it will not be lost. Then remove the back panel by gently sliding it towards the front.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Wade Vierheller
536 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 792
