Einleitung
If you happen to have sticky or broken keys, this guide will teach you how to replace an individual key on the keyboard.
Was du brauchst
Push working key back into place until it clicks. Make sure key is in correct position.
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
This article is linked under the "keys not working" section of a trouble shooting guide (Acer Aspire One 722 (P1VE6) Troubleshooting).
It's quite unlikely that just replacing the keycap will make the corresponding keystrokes register again. That would most likely require replacing the underlying microswitch, which is basically impossible.
