Zum Hauptinhalt wechseln
Acer Aspire One ZG5 Fan Replacement
Was du brauchst
  1. Acer Aspire One ZG5 Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
    Frag FixBot
    Kommentar hinzufügen
  2. Acer Aspire One ZG5 Fan Replacement: Schritt 2, Bild 1 von 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
    Frag FixBot
  3. Acer Aspire One ZG5 Fan Replacement: Schritt 3, Bild 1 von 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
    Frag FixBot
  4. Acer Aspire One ZG5 Fan Replacement, Wireless Card: Schritt 4, Bild 1 von 1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
    Frag FixBot
  5. Acer Aspire One ZG5 Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift up the panel and remove it from the case.
    Frag FixBot
  6. Acer Aspire One ZG5 Fan Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the two antenna cables from the left side of the wireless card.
    Frag FixBot
  7. Acer Aspire One ZG5 Fan Replacement: Schritt 7, Bild 1 von 1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
    Frag FixBot
  8. Acer Aspire One ZG5 Fan Replacement: Schritt 8, Bild 1 von 1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
    Frag FixBot
  9. Acer Aspire One ZG5 Fan Replacement, Keyboard: Schritt 9, Bild 1 von 1
    • Turn the netbook over and open the display so that the keyboard is facing you.
    Frag FixBot
  10. Acer Aspire One ZG5 Fan Replacement: Schritt 10, Bild 1 von 3 Acer Aspire One ZG5 Fan Replacement: Schritt 10, Bild 2 von 3 Acer Aspire One ZG5 Fan Replacement: Schritt 10, Bild 3 von 3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
    Frag FixBot
  11. Acer Aspire One ZG5 Fan Replacement: Schritt 11, Bild 1 von 2 Acer Aspire One ZG5 Fan Replacement: Schritt 11, Bild 2 von 2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
    Frag FixBot
  12. Acer Aspire One ZG5 Fan Replacement: Schritt 12, Bild 1 von 2 Acer Aspire One ZG5 Fan Replacement: Schritt 12, Bild 2 von 2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
    Frag FixBot
  13. Acer Aspire One ZG5 Fan Replacement, Top Case: Schritt 13, Bild 1 von 1
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
    Frag FixBot
  14. Acer Aspire One ZG5 Fan Replacement: Schritt 14, Bild 1 von 2 Acer Aspire One ZG5 Fan Replacement: Schritt 14, Bild 2 von 2
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
    Frag FixBot
  15. Acer Aspire One ZG5 Fan Replacement: Schritt 15, Bild 1 von 1
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
    Frag FixBot
  16. Acer Aspire One ZG5 Fan Replacement: Schritt 16, Bild 1 von 3 Acer Aspire One ZG5 Fan Replacement: Schritt 16, Bild 2 von 3 Acer Aspire One ZG5 Fan Replacement: Schritt 16, Bild 3 von 3
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
    Frag FixBot
  17. Acer Aspire One ZG5 Fan Replacement: Schritt 17, Bild 1 von 2 Acer Aspire One ZG5 Fan Replacement: Schritt 17, Bild 2 von 2
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
    Frag FixBot
  18. Acer Aspire One ZG5 Fan Replacement: Schritt 18, Bild 1 von 2 Acer Aspire One ZG5 Fan Replacement: Schritt 18, Bild 2 von 2
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
    Frag FixBot
  19. Acer Aspire One ZG5 Fan Replacement, Internal Wireless Card: Schritt 19, Bild 1 von 1
    • Disconnect the two antenna cables from the right side of the wireless card.
    Frag FixBot
  20. Acer Aspire One ZG5 Fan Replacement: Schritt 20, Bild 1 von 1
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
    Frag FixBot
  21. Acer Aspire One ZG5 Fan Replacement: Schritt 21, Bild 1 von 1
    • Gently pull the wireless card to the right and slide it out of its socket.
    Frag FixBot
  22. Acer Aspire One ZG5 Fan Replacement, Motherboard: Schritt 22, Bild 1 von 1
    • Disconnect the display cable from the top left of the motherboard.
    Frag FixBot
  23. Acer Aspire One ZG5 Fan Replacement: Schritt 23, Bild 1 von 2 Acer Aspire One ZG5 Fan Replacement: Schritt 23, Bild 2 von 2
    • Disconnect the speaker cable from its socket on the motherboard.
    Frag FixBot
  24. Acer Aspire One ZG5 Fan Replacement: Schritt 24, Bild 1 von 1
    • Remove three 3.9 mm Phillips #1 screws from the small I/O board.
    • Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
    • Some laptops may instead have a single 4.7 mm Phillips #0 screw.
    Frag FixBot
  25. Acer Aspire One ZG5 Fan Replacement: Schritt 25, Bild 1 von 1
    • Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
    Frag FixBot
  26. Acer Aspire One ZG5 Fan Replacement: Schritt 26, Bild 1 von 1
    • Gently lift the I/O board up from the right side of the case.
    • The I/O board is attached to the motherboard by a short cable.
    Frag FixBot
  27. Acer Aspire One ZG5 Fan Replacement: Schritt 27, Bild 1 von 1
    • Lift the entire motherboard assembly out the case.
    Frag FixBot
  28. Acer Aspire One ZG5 Fan Replacement, Fan: Schritt 28, Bild 1 von 2 Acer Aspire One ZG5 Fan Replacement, Fan: Schritt 28, Bild 2 von 2
    • Disconnect the fan cable from the motherboard.
    Frag FixBot
  29. Acer Aspire One ZG5 Fan Replacement: Schritt 29, Bild 1 von 1
    • Remove the three 3.9mm screws using Phillips #1 screwdriver.
    Frag FixBot
  30. Acer Aspire One ZG5 Fan Replacement: Schritt 30, Bild 1 von 1
    • Lift the fan housing from the motherboard.
    Frag FixBot
Abschluss
10 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 7-49, Amido Fall 2010 Mitglied von Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Mitglieder
34 Anleitungen geschrieben
4 Kommentare zur Anleitung
Steps 4~8 show to remove the wireless card from its access panel outside the computer, then steps 19~21 show to remove it from the inside once the case is off.
Redundant?
I drink beer - Antwort Teilen
There are two wireless cards -- for that exact model it looks like bluetooth and 802.11n but different models may be different
nathan - Antwort Teilen
I couldn't ask for it to be any easier. Great job.
Ron Price - Antwort Teilen
The page layout is good.well done job.thanks for providing the repairing information about Acer aspire one.it is the very interesting web page.http://djnni.com
belly william - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 43
Insgesamt: 28,494
