Zum Hauptinhalt wechseln
Acer Aspire One ZG5 Hard Drive Replacement
Was du brauchst
  1. Acer Aspire One ZG5 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Hard Drive Replacement, Wireless Card: Schritt 4, Bild 1 von 1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
  9. Acer Aspire One ZG5 Hard Drive Replacement, Keyboard: Schritt 9, Bild 1 von 1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 10, Bild 1 von 3 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 10, Bild 2 von 3 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 10, Bild 3 von 3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  11. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 11, Bild 1 von 2 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 11, Bild 2 von 2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  12. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 12, Bild 1 von 2 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 12, Bild 2 von 2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
  13. Acer Aspire One ZG5 Hard Drive Replacement, Top Case: Schritt 13, Bild 1 von 1
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  14. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 14, Bild 1 von 2 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 14, Bild 2 von 2
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  15. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 15, Bild 1 von 1
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  16. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 16, Bild 1 von 3 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 16, Bild 2 von 3 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 16, Bild 3 von 3
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  17. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 17, Bild 1 von 2 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 17, Bild 2 von 2
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  18. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 18, Bild 1 von 2 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 18, Bild 2 von 2
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
  19. Acer Aspire One ZG5 Hard Drive Replacement, Internal Wireless Card: Schritt 19, Bild 1 von 1
    • Disconnect the two antenna cables from the right side of the wireless card.
  20. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 20, Bild 1 von 1
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  21. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 21, Bild 1 von 1
    • Gently pull the wireless card to the right and slide it out of its socket.
  22. Acer Aspire One ZG5 Hard Drive Replacement, Motherboard: Schritt 22, Bild 1 von 1
    • Disconnect the display cable from the top left of the motherboard.
  23. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 23, Bild 1 von 2 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 23, Bild 2 von 2
    • Disconnect the speaker cable from its socket on the motherboard.
  24. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 24, Bild 1 von 1
    • Remove three 3.9 mm Phillips #1 screws from the small I/O board.
    • Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
    • Some laptops may instead have a single 4.7 mm Phillips #0 screw.
  25. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 25, Bild 1 von 1
    • Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
  26. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 26, Bild 1 von 1
    • Gently lift the I/O board up from the right side of the case.
    • The I/O board is attached to the motherboard by a short cable.
  27. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 27, Bild 1 von 1
    • Lift the entire motherboard assembly out the case.
  28. Acer Aspire One ZG5 Hard Drive Replacement, Hard Drive: Schritt 28, Bild 1 von 1
    • Turn the motherboard over so that the RAM is facing up.
  29. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 29, Bild 1 von 2 Acer Aspire One ZG5 Hard Drive Replacement: Schritt 29, Bild 2 von 2
    • Disconnect the I/O board from the motherboard.
  30. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 30, Bild 1 von 1
    • Remove the two 4.7 mm Phillips #0 screws that hold down the hard drive.
  31. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 31, Bild 1 von 1
    • Pull the hard drive straight out from the motherboard.
  32. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 32, Bild 1 von 1
    • Remove the four 3.9 mm Phillips #1 screws from the hard drive casing.
    • There are two screws on each side of the casing.
  33. Acer Aspire One ZG5 Hard Drive Replacement: Schritt 33, Bild 1 von 1
    • Remove the upper and lower casing from the hard drive.
Abschluss
108 weitere Nutzer:innen haben diese Anleitung absolviert.
Doug Gallatin
6.310 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 7-49, Amido Fall 2010 Mitglied von Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Mitglieder
20 Anleitungen geschrieben
12 Kommentare
Excellent guide. This "student" should be promoted to "instructor" right away. Many thanks.
Rudy Fernandes - Antwort
This guide helped a lot with refurbishing my old ZG5. It now has a case that is not cracked, 1.5 GB memory, and a 240GB SSD. I get to put off Windows 10 for a while longer.
James Stallings - Antwort
Thanks a lot! i already upgrade memory from 1 to 1.5 on my acer. But i have a question, does the aoa 150 works faster with a ssd disk? i want to try with one of 240 gb. Anyone try it?
Martiniano Vera Enrique - Antwort
Not the easiest upgrade I've ever done (perhaps the most difficult, actually), but I got it done. Removing the keyboard was the trickiest step for me. Be patient. If you can work one of the corner releases, you can put a flat-blade screwdriver under the corner of the keyboard and work on the other releases (starting at the far corner, then the centre).
The other tricky problem I had was getting the little ribbon cable for the trackpad properly reconnected after completing the project. (I thought the keyboard cable would be the tricky part, but it turns out to be pretty easy.) Be patient and you'll be fine. You may want to test (with a mouse handy) before you reinsert the keyboard.
Thanks very much for this howto!
Jim MacKenzie - Antwort
I had one of these little beasts that my son gave away about 6 years ago. The person he gave it to returned it to him a month later because it would not turn on. It was a case of the boot sector problem that plagues the ZG5. I performed the repair described on the Acer web site and it has been running fine ever since. After installing Linux Mint (dual boot), it was finally given away again last summer. Now it seems it is coming back to me. This might be the time to upgrade it with an SSD. Thanks for this tutorial. I will probably be making use of it over the next few weeks.
Chuck Pilger - 02/23/2017
Chuck Pilger - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 16
Letzten 7 Tage: 91
Letzten 30 Tage: 431
Insgesamt: 275,440
