Zum Hauptinhalt wechseln
Acer Aspire One ZG5 Keyboard Replacement
Was du brauchst
  1. Acer Aspire One ZG5 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  5. Acer Aspire One ZG5 Keyboard Replacement: Schritt 5, Bild 1 von 3 Acer Aspire One ZG5 Keyboard Replacement: Schritt 5, Bild 2 von 3 Acer Aspire One ZG5 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  6. Acer Aspire One ZG5 Keyboard Replacement: Schritt 6, Bild 1 von 2 Acer Aspire One ZG5 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  7. Acer Aspire One ZG5 Keyboard Replacement: Schritt 7, Bild 1 von 2 Acer Aspire One ZG5 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Doug Gallatin
6.310 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 7-49, Amido Fall 2010 Mitglied von Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 7
Letzten 30 Tage: 21
Insgesamt: 24,432
