Zum Hauptinhalt wechseln
Acer Aspire R R5-471T-51UN SSD Replacement
Was du brauchst
  1. Acer Aspire R R5-471T-51UN SSD Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Aspire R R5-471T-51UN SSD Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Aspire R R5-471T-51UN SSD Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip your laptop over so the bottom is facing you.
    • Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
  2. Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 2, Bild 1 von 3 Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 2, Bild 2 von 3 Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 2, Bild 3 von 3
    • Insert the Jimmy between the back cover of the laptop and the base of the laptop and then slowly use the Jimmy to pry off the back cover of the laptop.
  3. Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 3, Bild 1 von 2 Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 3, Bild 2 von 2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws on the battery.
  4. Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 4, Bild 1 von 3 Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 4, Bild 2 von 3 Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 4, Bild 3 von 3
    • Gently and cautiously pinch the white ends of the battery connector cable and slowly pull it from the motherboard.
  5. Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 5, Bild 1 von 2 Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 5, Bild 2 von 2
    • Gently lift the battery out of the laptop.
    • Be cautious with the lithium ion battery as you remove it.
  6. Acer Aspire R R5-471T-51UN SSD Replacement, SSD: Schritt 6, Bild 1 von 2 Acer Aspire R R5-471T-51UN SSD Replacement, SSD: Schritt 6, Bild 2 von 2
    • Using the Phillips #0 screwdriver, unscrew the single 5mm screw holding the SSD in place.
  7. Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 7, Bild 1 von 2 Acer Aspire R R5-471T-51UN SSD Replacement: Schritt 7, Bild 2 von 2
    • Gently pull the SSD to the left and out of the assembly.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 849
