Zum Hauptinhalt wechseln
Acer Aspire R11 R3-131T-C1Z5 Battery Replacement
Was du brauchst
  1. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop on to its front, so that the back is facing up
    • Unscrew the twelve 19.05 mm PH#0 screws.
  2. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: Schritt 2, Bild 1 von 2 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: Schritt 2, Bild 2 von 2
    • At the left front corner of the laptop, under the intel sticker, press the sharp end of a metal spudger between the keyboard and the back cover to pry it apart.
  3. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Connect the clip of an anti-static wrist strap to any piece of metal on the computer.
    • It is important to ground yourself to avoid static.
  4. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: Schritt 4, Bild 1 von 2 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: Schritt 4, Bild 2 von 2
    • Locate the large black rectangle at the bottom . This is your battery.
    • If you see that your battery is oozing or bulging, step away from the device.
    • Remove the black electric tape that is on the rainbow colored cable at the top of the battery.
    • Gently pull on the cable to disconnect.
  5. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: Schritt 5, Bild 1 von 3 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: Schritt 5, Bild 2 von 3 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the two 12.7 mm PH#0 screws. One of these screws is located on the top of the left side of the battery and the other is located in the top of the right side of the battery.
    • Remove the battery
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Nicely done manual, however share your thoughts, my ‘puter showed critical battery, I replaced an original AC14B3K with a Flyten AC14B8K battery and I have -0- lights/power. What are your thoughts?
S M Sendele - Antwort
Concise, easy to follow instructions! Hint: make sure you remove ALL of the screws from the back, or it won’t come off
Dierdre - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 62
Insgesamt: 6,797
