Zum Hauptinhalt wechseln
Acer Aspire R5-471T-52EE Back Cover Replacement
Was du brauchst
  1. Acer Aspire R5-471T-52EE Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Aspire R5-471T-52EE Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Back Cover Replacement: Schritt 2, Bild 1 von 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 162
