Zum Hauptinhalt wechseln
Acer Aspire R5-571T-57Z0 Display Assembly Replacement
Was du brauchst
  1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the three 4.0 mm screws from the battery using a Phillips #00 screwdriver.
    • Unplug the cable connected to the RAM.
    • Carefully remove the battery.
  2. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: Schritt 2, Bild 1 von 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: Schritt 2, Bild 2 von 2
    • Remove the six 4.0 mm screws from the hinges using a Phillips #00 screwdriver.
  3. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 3, Bild 1 von 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 3, Bild 2 von 2
    • Peel back the stickers from the display cable.
  4. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 4, Bild 1 von 3 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 4, Bild 2 von 3 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 4, Bild 3 von 3
    • Hold back the film protecting the Wi-Fi card.
    • Disconnect the touch screen cable.
  5. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 5, Bild 1 von 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 5, Bild 2 von 2
    • Pull back the tape covering the connectors.
    • Detach the two connectors (one black wire, one white wire).
  6. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 6, Bild 1 von 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the touch control cable next to the black film.
  7. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 7, Bild 1 von 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: Schritt 7, Bild 2 von 2
    • Flip over the laptop and pull back to remove the display assembly.
Abschluss
Kevin Chen
133 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 1-2, Botvin Spring 2022 Mitglied von UMass Dartmouth, Team 1-2, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 223
