Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Shut down the laptop and disconnect the power cord
    • Shut down the laptop and disconnect the power cord
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over
  2. Remove the (6) visible 10mm T-7 screws Remove the (4) visible 6mm T-7 screws Use the blue plastic opening tool to carefully remove the rubber pad which covers the two remaining screws
    • Remove the (6) visible 10mm T-7 screws
    • Remove the (4) visible 6mm T-7 screws
    • Use the blue plastic opening tool to carefully remove the rubber pad which covers the two remaining screws
    • Remove the remaining (2) 10mm T-7 screws
  3. Carefully lift the cover upwards
    • Carefully lift the cover upwards
    • If the cover seems stuck use a spudger tool to pry the sides
Abschluss
F Fernandez
420 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 3-4, Hickman Winter 2015 Mitglied von USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 86
