Einleitung
This guide will show you how to replace a cracked display assembly on an Acer Aspire R7 laptop.
Was du brauchst
Remove the long middle rubber piece with a plastic spludger or small flat head screwdriver.
Remove the 2 torx screws.
Remove the small middle rubber piece with a plastic spludger or small flat head screwdriver.
Unscrew the torx screw. It is the same size as the bottom front row screws.
Disconnect the battery connector from the motherboard.
Remove the hard drive by slightly lifting it up on the left side and slightly pulling it to the left carefully untill it pops out.
Disconnect the two keyboard ribbon cables
Disconnect the left speaker wire.
Disconnect the front lights ribbon cable.
Disconnect the I/O board ribbon cable.
Remove the 3 heat sink screws.
Lift up the heat sink from the motherboard and remove it.
Remove the 4 silver hinge screws.
Remove the 2 black hinge screws.
Remove the 4 T9 torx screws from the display assembly where the model number and serial numbers stickers are located and swap that panel to the replacement display assembly. Completing this step allows for your computer to retain its original identification information.
9 weitere Personen haben diese Anleitung absolviert.
5 Kommentare zur Anleitung
I ordered the display on eBay.
This is just a teardown. Nobody sells the entire display assembly with shell, and the steps to go over replacing the actual display panel are completely absent.
Although correct this doesn't help and should probably be taken down. As mentioned by others you can't buy the entire screen section, you can only buy the LCD part. Replacing the LCD requires removing the glass and having to glue it back on which is probably beyond most people's capability. This article is therefore misleading.
