Einleitung
This guide will show you how to replace the hard drive in your Acer Aspire R7-371T-72CF.
Was du brauchst
Turn off your laptop and disconnect the power adapter.
Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
Locate the hard drive, as shown to the left. This can be identified by its location underneath the cooling fan and above the ribbon cable (the long horizontal white strip).
Remove the hard drive by pulling towards the side that was secured by the screw.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
