Zum Hauptinhalt wechseln
Acer Aspire R7-371T-72CF Power Port Replacement
Was du brauchst
  1. Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: Schritt 1, Bild 1 von 2 Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: Schritt 1, Bild 2 von 2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Power Port Replacement: Schritt 2, Bild 1 von 1
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Power Port Replacement: Schritt 3, Bild 1 von 3 Acer Aspire R7-371T-72CF Power Port Replacement: Schritt 3, Bild 2 von 3 Acer Aspire R7-371T-72CF Power Port Replacement: Schritt 3, Bild 3 von 3
    • Locate the power connector, as shown on the left.
    • The power connector will be in the same location as where you normally plug the charger into the laptop to charge your device.
  4. Acer Aspire R7-371T-72CF Power Port Replacement: Schritt 4, Bild 1 von 3 Acer Aspire R7-371T-72CF Power Port Replacement: Schritt 4, Bild 2 von 3 Acer Aspire R7-371T-72CF Power Port Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the wiring from the motherboard, and pull out the rest of the wire carefully.
    • Make sure the wire is not caught on anything before pulling.
  5. Acer Aspire R7-371T-72CF Power Port Replacement: Schritt 5, Bild 1 von 1
    • Pull out the power connector by pulling upwards on the wires.
    • This may require a small amount of force, but should pop out with some pressure.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ethan Frey
117 Reputation
1 Anleitung geschrieben
Cal Poly, Team S8-G5, Banghart Fall 2017 Mitglied von Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
5 Mitglieder
5 Anleitungen geschrieben
4 Kommentare
What’s the part number for the power jack cable, and who sells it?
AcerFan - Antwort
50.mqpn7.001 (SIQDD0ZS8AD001)
I found it here: https://www.itpartsource.com/50MQPN7001-...
Jorge Prado - Antwort
What model is this? Is this the older (~2015) model with the small cylindrical charging port?
Sarah - Antwort
The associated part id numbers for the Acer R7-371t 45W DC Jack Cable are:
50.MQPN7.001
SIQDD0ZS8AD001
Unfortunately, I have found this part impossible to find in stock at any source.
rosemank - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 1,697
