Einleitung
This guide will show you the steps that need to be taken to replace a faulty USB chip.
Was du brauchst
Turn off your laptop and disconnect the power adapter.
Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
Push the white panel upwards to unlock the cable and then remove the cable.
Repeat for the second cable.
Eine weitere Person hat diese Anleitung absolviert.
