Zum Hauptinhalt wechseln
Acer Aspire R7-371T-72CF Wifi Chip Replacement
Was du brauchst
  1. Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: Schritt 1, Bild 1 von 2 Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: Schritt 1, Bild 2 von 2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Wifi Chip Replacement: Schritt 2, Bild 1 von 1
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Wifi Chip Replacement: Schritt 3, Bild 1 von 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: Schritt 3, Bild 2 von 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: Schritt 3, Bild 3 von 3
    • Locate the wifi chip, as shown to the left.
    • The chip can by identified by the white and black wires connected to it, as well as a single screw holding it in place.
  4. Acer Aspire R7-371T-72CF Wifi Chip Replacement: Schritt 4, Bild 1 von 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: Schritt 4, Bild 2 von 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: Schritt 4, Bild 3 von 3
    • Locate the 2 antenna wires connected to the chip.
    • One is black, and the other is white.
    • Use a spudger or plastic opening tool to carefully disconnect the wires from the chip by prying upwards.
    • The connectors 'click' into place, like a button.
  5. Acer Aspire R7-371T-72CF Wifi Chip Replacement: Schritt 5, Bild 1 von 2 Acer Aspire R7-371T-72CF Wifi Chip Replacement: Schritt 5, Bild 2 von 2
    • Remove the Phillips #00 6mm securing screw using your screwdriver.
  6. Acer Aspire R7-371T-72CF Wifi Chip Replacement: Schritt 6, Bild 1 von 1
    • Remove the chip by pulling towards the edge of the computer.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S8-G5, Banghart Fall 2017 Mitglied von Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
5 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Any idea on screen replacement for this particular model? I’ve been searching for a video all week. Please help me out if possible
Hasan Mahmood - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 545
