Einleitung
This guide will show you how to improve your wifi signal by replacing a weak or broken wifi chip.
Was du brauchst
Turn off your laptop and disconnect the power adapter.
Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
Locate the 2 antenna wires connected to the chip.
Use a spudger or plastic opening tool to carefully disconnect the wires from the chip by prying upwards.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Any idea on screen replacement for this particular model? I’ve been searching for a video all week. Please help me out if possible
