Zum Hauptinhalt wechseln
Acer Aspire R7-572-6423 Hard Drive Replacement
Was du brauchst
  1. Acer Aspire R7-572-6423 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Acer Aspire R7-572-6423 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Acer Aspire R7-572-6423 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove the top and middle grips that conceal 3 additional screws.
    • Remove the 5 6mm T9 screws.
    • Remove the 8 10mm T9 screws.
  3. Acer Aspire R7-572-6423 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover.
  4. Acer Aspire R7-572-6423 Hard Drive Replacement: Schritt 4, Bild 1 von 3 Acer Aspire R7-572-6423 Hard Drive Replacement: Schritt 4, Bild 2 von 3 Acer Aspire R7-572-6423 Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the four 4mm PH0 screws holding the hard drive in place.
  5. Acer Aspire R7-572-6423 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Tilt the hard drive up and pull it away and out of its base.
    • Do not use too much force on the hard drive or tilt it so much that the base is broken.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 1,609
