Zum Hauptinhalt wechseln
Acer Aspire S3 MS2346 Display Assembly Replacement
Was du brauchst
  1. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: Schritt 1, Bild 2 von 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: Schritt 2, Bild 1 von 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: Schritt 2, Bild 2 von 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: Schritt 2, Bild 3 von 3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Display Assembly Replacement: Schritt 3, Bild 1 von 2 Acer Aspire S3 MS2346 Display Assembly Replacement: Schritt 3, Bild 2 von 2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: Schritt 5, Bild 1 von 2 Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: Schritt 5, Bild 2 von 2
    • Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
  6. Acer Aspire S3 MS2346 Display Assembly Replacement: Schritt 6, Bild 1 von 1
    • Unlatch the screen from the frame
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Washington State, Team S1-G4, Hope Fall 2018 Mitglied von Washington State, Team S1-G4, Hope Fall 2018
WSU-HOPE-F18S1G4
3 Mitglieder
6 Anleitungen geschrieben
3 Kommentare
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - Antwort
You can find this screen on 3rd party sites such as newegg and ebay.
Stacy Schauls -
Please arrange me a screen for this acer aspire S3 ms 2346
Amit Gangwar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 3,101
