Einleitung
This guide will be used when a battery will not charge when connected to a charger. The battery is connected to many wires, so when disconnecting wires be cautious as the wires could become damaged and will also need to be replaced.
Was du brauchst
With the Phillips #1 screwdriver, remove the two 5mm screws located on either side of the battery.
Pull upwards on the plugs located on top of your battery until they have completely come off.
Remove the electrical tape holding down the battery by peeling it upwards.
Grab the battery from the bottom and slide it out towards the direction of the bottom of the battery.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
