Einleitung
If your Acer Aspire S3-391-6046 ultrabook is overheating, it might be a problem with the fan assembly. This is a guide for how to remove and replace it.
Was du brauchst
Use the tweezers to gently pull the small black plug out.
After the plug is out, you should be able to pull the fan assembly out.
Fast fertig!
Abschluss
