Zum Hauptinhalt wechseln
Acer Aspire S3-391-6046 Keyboard Replacement
Was du brauchst
  1. Acer Aspire S3-391-6046 Keyboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 2, Bild 1 von 2 Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Remove the four Phillips #0 screws that are connected to the left and right speakers.
    • Carefully disconnect the wires that connect the speaker to the rest of the computer.
  5. Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove two Phillips #0 screws that are beside the ends of the gray wire.
  6. Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 6, Bild 1 von 3 Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 6, Bild 2 von 3 Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the gray wire slowly with tweezers.
    • Carefully peel wire off.
  7. Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 7, Bild 1 von 2 Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Slowly remove the two wires that are to the left of the battery with tweezers in an upward pulling motion.
  8. Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 8, Bild 1 von 2 Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Completely remove the battery out of its position.
  9. Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 9, Bild 1 von 2 Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Remove the five Phillips #0 screws that are on the border of the laptop.
    • Disconnect the white wire that is below the fan.
  10. Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 10, Bild 1 von 2 Acer Aspire S3-391-6046 Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Flip all of the circuits upwards.
    • Remove all Phillips #0 screws.
    • Remove the keyboard.
Abschluss
Brian Jimenez
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 833
