Zum Hauptinhalt wechseln
Acer Aspire S3-391-6046 Screen Replacement
Was du brauchst
  1. Acer Aspire S3-391-6046 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Acer Aspire S3-391-6046 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Acer Aspire S3-391-6046 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Slide the plastic opening tool underneath the frame of your device.
    • Slide the plastic opening tool all around the frame until the entire frame becomes loose and comes off.
  2. Acer Aspire S3-391-6046 Screen Replacement: Schritt 2, Bild 1 von 3 Acer Aspire S3-391-6046 Screen Replacement: Schritt 2, Bild 2 von 3 Acer Aspire S3-391-6046 Screen Replacement: Schritt 2, Bild 3 von 3
    • On the bottom left of the screen there is a black cable with a piece of white tape over it. Remove the white tape by peeling it off.
    • Slide your opening tool underneath the front of the cable, and pull the cable upwards to disconnect it from its socket.
  3. Acer Aspire S3-391-6046 Screen Replacement: Schritt 3, Bild 1 von 3 Acer Aspire S3-391-6046 Screen Replacement: Schritt 3, Bild 2 von 3 Acer Aspire S3-391-6046 Screen Replacement: Schritt 3, Bild 3 von 3
    • Peel the silver tape from the corner of your laptop until it fully comes off.
  4. Acer Aspire S3-391-6046 Screen Replacement: Schritt 4, Bild 1 von 3 Acer Aspire S3-391-6046 Screen Replacement: Schritt 4, Bild 2 von 3 Acer Aspire S3-391-6046 Screen Replacement: Schritt 4, Bild 3 von 3
    • Remove the screen by grabbing the edges of the screen and pulling forward.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Hi! Apparently three films came off with the LCD. Clear,gray and black what are they?
Coolboy_Awesome - Antwort
Thank you. Excellent instructions allowing me to replace LCD ribbon
M Geyer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 1,672
