Zum Hauptinhalt wechseln
Acer Aspire S7-392-6484 Battery Replacement
Was du brauchst
  1. Acer Aspire S7-392-6484 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire S7-392-6484 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
    • Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
    • After all marked screws have been removed, lift up back panel to expose internal parts.
  2. Acer Aspire S7-392-6484 Battery Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the marked 1.5 mm screws with a Phillips #01 screwdriver.
  3. Acer Aspire S7-392-6484 Battery Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the cable located at the top of the battery. Be careful to pull the cable horizontally, not vertically.
  4. Acer Aspire S7-392-6484 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Nicholas Wise
754 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S2-G6, Eyestone Spring 2018 Mitglied von USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 5,501
