Einleitung
The fan often needs replacement if the device is overheating or making loud noises while running. Some common tools will be needed for this replacement, such as a T6 Torx screwdriver and a Phillips #01 screwdriver. To determine if the fan needs to be replaced, please refer to this device's troubleshooting page.
Was du brauchst
Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
Remove the fan by disconnecting the marked tabs.
Eine weitere Person hat diese Anleitung absolviert.
