Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  2. Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
    • Remove the hard drive by pulling it away horizontally from its connection.
Abschluss
Nicholas Wise
Mitglied seit 14.02.2018
595 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S2-G6, Eyestone Spring 2018 Mitglied von USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 147
