Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver. Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  2. Unscrew the marked 2mm screws with a Phillips #01 screwdriver. Remove the fan by disconnecting the marked tabs.
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Remove the marked 2mm screw with a Phillips #01 screwdriver.
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  5. Remove the hard drive by pulling it away horizontally from its connection.
    • Remove the hard drive by pulling it away horizontally from its connection.
Abschluss
Nicholas Wise
595 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S2-G6, Eyestone Spring 2018 Mitglied von USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 92
Insgesamt: 700
