Einleitung
How to replace the solid state drive in an Acer Aspire S7-392-6484.
Was du brauchst
Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
Remove the fan by disconnecting the marked tabs.
3 weitere Personen haben diese Anleitung absolviert.
