Zum Hauptinhalt wechseln
Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement
Was du brauchst
  1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 2, Bild 1 von 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 2, Bild 2 von 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • There are four zero insertion force connectors that need to be removed.
    • Use your plastic opening tool to flip up the black clips that secure the ribbon cables to the motherboard.
    • Once the clips are flipped up, the ribbon cables will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 3, Bild 1 von 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 3, Bild 2 von 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use your plastic opening tool to pry up and lift the antenna cables from the motherboard.
    • The connectors are delicate so use a gentle touch when prying them.
  4. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 4, Bild 1 von 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 4, Bild 2 von 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • To remove the four bundle cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  5. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 5, Bild 1 von 2 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use your screwdriver with the Phillips PH000 attachment to remove the three 4mm screws.
    • Remove the motherboard from the tablet.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Max Francois
684 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 3-4, Passmore Fall 2016 Mitglied von USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 24
Insgesamt: 7,369
