Zum Hauptinhalt wechseln
Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement
Was du brauchst
  1. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement, Touchpad: Schritt 1, Bild 1 von 1
    • Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
    • This screw does not need to be removed because it doesn't hold the backplate in.
  2. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: Schritt 2, Bild 1 von 2 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: Schritt 2, Bild 2 von 2
    • Push the plastic opening tool into the crevice between the front and back panel.
    • Pull down on the plastic opening tool like a lever to create space and slide along the crevice to remove the back panel.
  3. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: Schritt 3, Bild 1 von 3 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: Schritt 3, Bild 2 von 3 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: Schritt 3, Bild 3 von 3
    • Gently slide the plastic opening tool under the black clip that is attached to the ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  4. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: Schritt 4, Bild 1 von 1
    • Remove the touchpad.
Abschluss
Max Francois
684 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 3-4, Passmore Fall 2016 Mitglied von USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
Thank you for the steps. I want to know if a replacement keyboard is available in the market. I did not find online.
Gibson Castelino - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 1,569
