Zum Hauptinhalt wechseln
Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement
Was du brauchst
  1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: Schritt 1, Bild 1 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: Schritt 1, Bild 2 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: Schritt 1, Bild 3 von 3
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover using the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 2, Bild 1 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 2, Bild 2 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 2, Bild 3 von 3
    • Remove the yellow tape from the board cables.
    • Carefully unplug the two board cables from their connectors by pulling on them.
  3. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 3, Bild 1 von 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 3, Bild 2 von 2
    • Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place.
  4. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 4, Bild 1 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 4, Bild 2 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 4, Bild 3 von 3
    • Lift up the metal tab on the left side using the opening tool.
    • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  5. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 5, Bild 1 von 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 5, Bild 2 von 2
    • Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place.
  6. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 6, Bild 1 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 6, Bild 2 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 6, Bild 3 von 3
    • Lift the metal tab on the right side up using the opening tool.
  7. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 7, Bild 1 von 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 7, Bild 2 von 2
    • Insert the opening tool between the two sections of the device.
    • Lift up the keyboard section using the opening tool.
  8. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 8, Bild 1 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 8, Bild 2 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 8, Bild 3 von 3
    • Carefully pull up on the keyboard section using your hands to remove it from the screen section.
  9. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 9, Bild 1 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 9, Bild 2 von 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: Schritt 9, Bild 3 von 3
    • Pull the docking connector off of the screen section.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Grecia Corrada
1.134 Reputation
6 Anleitungen geschrieben
Baylor, Team S3-G3, Williams Spring 2018 Mitglied von Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 Mitglieder
Ein Kommentar
Where do you get the docking ports or whatever it is called? With the magnets
Michael - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 29
Insgesamt: 2,944
