Einleitung
If your Acer Aspire Switch 10 isn’t producing clear audio—distorted, intermittent, or no sound, use this guide to replace the speakers in your device. The speakers on the device are responsible for the audio. Before using this guide make sure your sound settings are turned on. Before beginning, make sure to power off your device completely and disconnect from any external power source.
Was du brauchst
Remove the tablet from the keyboard
Use the opening tool to release the back plate of the laptop.
Lift the back plate off the laptop.
Remove the speaker connector.
Use the opening tool to carefully slide the cable out of its port.
Eine weitere Person hat diese Anleitung absolviert.
