Einleitung
Before performing any repairs, make sure the laptop is fully powered off and disconnected from its charger. Replacing the audio drive involves first removing the keyboard, battery and the motherboard.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. With laptop closed and powered off, place the laptop screen side down.
    • With laptop closed and powered off, place the laptop screen side down.
    • Turn the laptop so that the hinges are closest to you.
    • Unscrew all sixteen 6mm Phillips #J00 screws on the bottom of the laptop with the #J00 Phillips head screwdriver.
  2. Once unscrewed, flip laptop over. Rotate laptop 180 degrees, so you can open the screen.
    • Once unscrewed, flip laptop over.
    • Rotate laptop 180 degrees, so you can open the screen.
    • Open the laptop screen.
    • Use the plastic opening tool with the half centimeter wide tip to gently separate the bottom case of the laptop from the keyboard.
    • Do not apply too much force or you may break the clips.
    • Gently pull the keyboard upwards to a 45 degree angle.
  3. Hold the keyboard open with one hand to extend  the three cables (white, black and copper) still connecting the bottom of the keyboard to the back case. Be sure you are prying up the hinged retaining flap, not the connector itself. Use your fingernail to flip up the small retaining flap of each zero insertion force connector and then gently pull each ribbon cable out one at a time.
    • Hold the keyboard open with one hand to extend the three cables (white, black and copper) still connecting the bottom of the keyboard to the back case.
    • Be sure you are prying up the hinged retaining flap, not the connector itself.
    • Use your fingernail to flip up the small retaining flap of each zero insertion force connector and then gently pull each ribbon cable out one at a time.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
  4. Use both hands to remove the keyboard. Do not pull too forcibly or you could damage your keyboard.
    • Use both hands to remove the keyboard.
    • Do not pull too forcibly or you could damage your keyboard.
  5. After removing the keyboard, open the laptop screen to face you.
    • After removing the keyboard, open the laptop screen to face you.
    • Gently disconnect the silver cable that stretches over the battery by using your fingernail to flip up the small retaining flaps on both sides of the zero insertion force connector.
  6. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Unscrew one 3mm #J1 Phillips screw from the side closest to you of the motherboard with a #J1 Phillips head screwdriver.
    • Unscrew one 3mm #J1 Phillips screw from the side closest to you of the motherboard with a #J1 Phillips head screwdriver.
    • Unscrew one 4mm #J1 Phillips screw from the right of the motherboard with a #J1 Phillips head screwdriver.
  8. Use your fingernail to flip up the small retaining flap of the zero insertion force connector and then gently pull out the silver ribbon cable. Be sure you are prying up the hinged retaining flap, not the connector itself.
    • Use your fingernail to flip up the small retaining flap of the zero insertion force connector and then gently pull out the silver ribbon cable.
  9. Gently disconnect the six cables (red, black and green) attached to both the battery and motherboard by pinching them with your thumb and forefinger. Pull with moderate force towards the left to disconnect. Gently disconnect the six cables (red, black and green) attached to both the battery and motherboard by pinching them with your thumb and forefinger. Pull with moderate force towards the left to disconnect.
    • Gently disconnect the six cables (red, black and green) attached to both the battery and motherboard by pinching them with your thumb and forefinger. Pull with moderate force towards the left to disconnect.
  10. Gently lift up the black-covered cables that remain connected to the motherboard at the bottom left of the laptop base. Move the cables toward the bottom edge of the laptop closest to you without disconnecting them. Do not pull too forcibly or you could damage your motherboard. Carefully lift up the motherboard and slide the battery to the left to pull it out.
    • Gently lift up the black-covered cables that remain connected to the motherboard at the bottom left of the laptop base. Move the cables toward the bottom edge of the laptop closest to you without disconnecting them.
    • Do not pull too forcibly or you could damage your motherboard.
    • Carefully lift up the motherboard and slide the battery to the left to pull it out.
  11. Use your fingernail to flip up the small retaining flap of zero insertion force connector and then gently out pull the silver ribbon cable. Be sure you are prying up the hinged retaining flap, not the connector itself.
    • Use your fingernail to flip up the small retaining flap of zero insertion force connector and then gently out pull the silver ribbon cable.
  12. Gently use your fingernail to push the white ribbon cable away from its connector. To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable. To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
    • Gently use your fingernail to push the white ribbon cable away from its connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
  13. Gently use your fingernail to push the white ribbon cable away from its connector. To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable. To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
  14. Gently lift up the motherboard with your hands to remove it. Gently lift up the motherboard with your hands to remove it.
    • Gently lift up the motherboard with your hands to remove it.
  15. Use the #J1 Phillips Head screwdriver to unscrew three 4 mm #J1 screws from the side of the motherboard closest to you. Pick up the audio drive from bottom left corner of computer.
    • Use the #J1 Phillips Head screwdriver to unscrew three 4 mm #J1 screws from the side of the motherboard closest to you.
    • Pick up the audio drive from bottom left corner of computer.
  16. Lift motherboard and gently pull audio drive wire towards you until the wire is free. Lift speaker at bottom right of computer to remove the audio drive. Lift speaker at bottom right of computer to remove the audio drive.
    • Lift motherboard and gently pull audio drive wire towards you until the wire is free.
    • Lift speaker at bottom right of computer to remove the audio drive.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Margaret Bruetsch
384 Reputation
2 Anleitungen geschrieben
Marist, Team 1-2, Laflen Spring 2016 Mitglied von Marist, Team 1-2, Laflen Spring 2016
MARS-LAFLEN-S16S1G2
3 Mitglieder
6 Anleitungen geschrieben
Hi I have acer aspire m5 481tg before 2 weeks its shut down and no more working ,I replaced motherboard ram but still not working please help me ,if any one can help me contact me starlov@gmail.com
Ali - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 351
