Zum Hauptinhalt wechseln
Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement
Was du brauchst
  1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn your laptop over, and find the laptop battery release button locks for your Acer laptop.
  2. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 2, Bild 1 von 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 2, Bild 2 von 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 2, Bild 3 von 3
    • Hold the battery release button, and pull the battery out of the laptop.
  3. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: Schritt 3, Bild 1 von 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: Schritt 3, Bild 2 von 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: Schritt 3, Bild 3 von 3
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  4. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 4, Bild 1 von 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 4, Bild 2 von 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 4, Bild 3 von 3
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  5. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 5, Bild 1 von 2 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  6. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 6, Bild 1 von 2 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 6, Bild 2 von 2
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  7. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 7, Bild 1 von 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 7, Bild 2 von 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: Schritt 7, Bild 3 von 3
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
  8. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: Schritt 8, Bild 1 von 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: Schritt 8, Bild 2 von 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: Schritt 8, Bild 3 von 3
    • Detach the covered wires that connect the motherboard to the Bluetooth.
    • Remove the Bluetooth module by hand to then replace it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 27
Insgesamt: 804
