Einleitung
This guide will assist you in replacing a fan that no longer works.
Ersatzteile
Keine Ersatzteile angegeben.
Turn your laptop over, and find the laptop battery release button locks for your Acer laptop.
Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
Pry open the cover using the Spudger tool.
Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
Carefully remove the charger attachment in the top left.
Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
