Zum Hauptinhalt wechseln
Acer Aspire TimelineX 1830T-68U118 RAM Replacement
Was du brauchst
  1. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: Schritt 1, Bild 1 von 3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: Schritt 1, Bild 2 von 3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Remove the device's battery before beginning.
    • Turn laptop so under side is facing up.
    • Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
  2. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 2, Bild 1 von 1
    • Pry open hard drive cover using the Spudger tool.
  3. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 3, Bild 1 von 3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 3, Bild 2 von 3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 3, Bild 3 von 3
    • Remove screw attached to the hard drive using the PH0 mm Phillips Head.
    • The hard drive can now be removed from the device.
  4. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: Schritt 4, Bild 1 von 3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: Schritt 4, Bild 2 von 3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: Schritt 4, Bild 3 von 3
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  5. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 5, Bild 1 von 3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 5, Bild 2 von 3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 5, Bild 3 von 3
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  6. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 6, Bild 1 von 2 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  7. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 7, Bild 1 von 2 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 7, Bild 2 von 2
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  8. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 8, Bild 1 von 3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 8, Bild 2 von 3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 8, Bild 3 von 3
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
  9. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, RAM: Schritt 9, Bild 1 von 1
    • After removing the motherboard, turn it over so that the back side is facing you.
  10. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 10, Bild 1 von 1
    • To release the RAM from the motherboard, press both of the metal prongs on the sides of the RAM.
  11. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 11, Bild 1 von 1
    • After RAM memory card is released from the motherboard, hold the RAM card on a 45 degree angle and remove the card.
  12. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: Schritt 12, Bild 1 von 1
    • Install your new RAM memory card following these steps in reverse.
Abschluss
Ein Kommentar
Stupid! you can remove the ram after step 2!!!
Erlend - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 558
