Einleitung
In this guide, you will be able to replace your laptop's RAM with step by step help. The RAM is located on the motherboard.
Was du brauchst
Turn laptop so under side is facing up.
Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
Remove screw attached to the hard drive using the PH0 mm Phillips Head.
The hard drive can now be removed from the device.
Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
Pry open the cover using the Spudger tool.
Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
Carefully remove the charger attachment in the top left.
Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
After removing the motherboard, turn it over so that the back side is facing you.
To release the RAM from the motherboard, press both of the metal prongs on the sides of the RAM.
After RAM memory card is released from the motherboard, hold the RAM card on a 45 degree angle and remove the card.
